Windows master browser error id: 8003
jalexander41
I have had the above Windows browsing error & have found the resolution that says to enter the 'no ip forward-protocol udp' command on the routers where the 'ip helper'command is enabled. This removes other default broadcast forwarding. Has anyone else done this & was it successful?
gmarogi
Level 5
Level 5
May be the problem was due to a duplex mis-match on the switch that the router was connected to.
