WIRELESS COMMUNICATION USING WIFI MODULES THROUGH MAC ADDRESS
SUDHEER.NULU
I am involved in a project where module to module communication has to be done using WIFI MODULE through MAC ADDRESS.
I want to know whether it is possible to communicate using MAC
Peter Paluch
Yes, it is possible to communicate using MAC addresses - that is why they exist in the first place. However, addressing the communication using MAC addresses suggests that in your project, you are not going to use IPv4 or IPv6, and instead, you are going to insert your messages directly into Layer2 frames. Is this correct?
Best regards,
Peter
