With a public block of IPs, can I use multiple ISPs on an ASA
Lameth
My company has tasked me with shutting down our datacenter and moving everything into one of our sites.  Currently the datacenter supplies us with a /24 block and I would like to replicate this at one of our sites.  However, the datacenter supplies us with multi ISP which is something I can not get.  At my site, I have 2 ISPs using SLA for failover.  Each have their own block of IPs and each provide me a /27 so I can do limited outbound natting.  If I were to lease a /24 block of IPs, What would I need to do with these carriers and IPs to make this work?
This is all through an ASA 5525x.  Would it be a matter of enabling BGP with the ISPs?  (right now as we do not have a lot of routes, everything is static and has been great for years).  If I am leasing the IPs internally, would I need to apply for an AS # for my company?  I am just not sure where to start with this.
6 Replies 6
The new location can ISP advertise these public IP (from old DC)?
MHM
The current datacenter IPs are owned by the datacenter and are not transferable.  I think that's what your are asking?
There are things about your environment that we do not know and that impacts our ability to give good advice. If you have a /24 block of addresses I would have thought you could advertise them from a different data center. I am not clear why the IPs are not transferable. But if they are not transferable then it seems that you are stuck with what you have got.
Rick
I think perhaps I explained incorrectly.  Lets ignore the transfer from a datacenter.  I currently have 2 ISPs at my location both connected to a single ASA 5525.  Currently I use static routes and SLA to handle fail over.  If I acquire a /24 subnet, how with the ASA 5525 would I be able to use this /24 across both ISPs?
Thanks for the clarification. If you acquire a block of /24 Public IPs then you would run BGP on your ASA and advertise your block of addresses to both ISP. And if you need to move to a different location then you would run BGP from the new location and advertise your Public IPs from the new location.
Rick
that's kind of what I was thinking.  Now with this setup, my company would need to acquire an AS#  , I wouldn't be able to go off of the ISPs ?
