wlan-ap clients, cannot access external resources
eldin.didic
Hi Guys,
Just configured this 887VA-W for the first time using CLI and am having an understanding issue regarding communcation between wlan clients and external resources.
Configured the AP successfully as far as connecting and authentication goes. Communication works to and from the AP clients on the LAN side, but the issue appears to be communication between the AP clients and the internet. I cannot ping 8.8.8.8 from the AP clients.
I read through gone over external configuration examples, but just cannot seem to get this part correct. Perhaps I have not been persistent enough with it, but I have spent the last two days trying to figure it out. Some help would do wonders on my end obviously.
Here are both configs from the router and ap.
ROUTER Config:
hostname <ourgatewayname>
boot-start-marker
boot-end-marker
logging buffered informational
no logging console
enable secret 4 <removed for posting purposes>
aaa new-model
aaa session-id common
clock timezone UTC 10 0
crypto pki trustpoint TP-self-signed-2776889875
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2776889875
revocation-check none
rsakeypair TP-self-signed-2776889875
crypto pki certificate chain TP-self-signed-2776889875
certificate self-signed 01
        quit
ip source-route
ip cef
ip domain name <our-internal-domain-name>
ip name-server 192.168.2.15
ip name-server 192.168.2.16
ip name-server 192.168.3.11
ip name-server 8.8.8.8
no ipv6 cef
license udi pid C887VA-W-A-K9
username administrator privilege 15 secret 4 <thepassword>
controller VDSL 0
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
ip flow ingress
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Ethernet0
no ip address
shutdown
no fair-queue
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 192.168.2.2 255.255.255.0
ip access-group vlan-control in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer1
description ADSL WAN Dialer
ip address<removed for posting purposes> 255.255.255.0
ip access-group dialer-acl in
no ip redirects
no ip unreachables
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname <theusername>
ppp chap password 0 <thepassword>
ppp pap sent-username <theusername> password 0 <thepassword>
ppp ipcp route default
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat <removed for posting purposes>
ip route <removed for posting purposes>
ip access-list extended dialer-acl
ip access-list extended internal-nat-list
ip access-list extended terminal-acl
ip access-list extended vlan-control
logging trap debugging
dialer-list 1 protocol ip permit
no cdp run
AP Config:
dot11 syslog
dot11 ssid drh-corp
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 0 <thessidpassword>
username administrator privilege 15 secret 5 <thepassword>
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm tkip
encryption mode ciphers aes-ccm tkip
ssid drh-corp
antenna gain 0
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
world-mode dot11d country-code AU indoor
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.2.245 255.255.255.0
no ip route-cache
ip default-gateway 192.168.2.2
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
Thanks...
eldin.didic
I found the problem. The issue is that I am using an internal DHCP server to assign client IP configuration.
What I need to know now is there a way I can force this AP to continue using the internal DHCP server for IP configuration but force an alternative default gateway instead of the DHCP assigned gateway?
I need 192.168.2.2 as the default gateway for the AP connected clients instead of 192.168.2.1 default gateway that the DHCP server assigns.
This would save me creating reservations on the DHCP server and manually overriding the default gateway for all AP connected clients.
I need an override DHCP option.
Thanks...
