write memory without effect
watocisco
hello
my 1841 router not keep at the reload my basic config although the cmd copy running-config startup-config or write memory
Richard Burts
Eric
The most common cause of this symptom is that the config register has been set to 0x2142 which causes the router to ignore startup-config at boot time.
The easy way to check the setting of the config register is to do show version and look down toward the bottom of the display where it should show the config register value.
If it is 0x2142 then you should change it to 0x2102.
Rick
Rick
i try with 2102 and its ok
thank you
Eric
I am glad that you got it straightened out.
Rick
Rick
