WS-C3560X-24 can't view show key chain
Nikolay Savin
I have devices
WS-C3560X-24
Version 12.2(53r)SE2
I need check configuration of eigrp key chain
in manual i found command
show key chain <my_key>
but when i try do it, i receive error
% Ambiguous command:  "show key chain eigrp-chain"
Anyone kwon why the problem was happen?
Bilal Nawaz
Just try 'show key chain' you should be able to see the key details in the output.
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
