WS-SUP720-3B - 2 Full BGP Table - Max Routing Table?
Hi everyone..
In datasheet of  WS-SUP720-3B - link- was said that are only supported around 256K routes (fib?rib?)..
With this value I can't get 2 full bgp - that is around 850K ..
The supervisor is that control this or just memory ?
I said this because I have a 7204-npe-g1 whith 2 fullrouting and 1G of and he are ok..
Alex
Raju Sekharan
Hi Alex
7600 does Hardware forwarding of packets. 7200 is a CEF router and packets are cef switched and it doesn't use any Hardware ASICfor paket forwarding.
256K limitation on SUP720-3B is becasue of the FIB TCAM which is used for hardware forwarding.
Raju
Thanks Raju.
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
BTW, the 720 XL variant handles much larger route tables.
