X25 issue...who's to blame
danilo.dicesare
HI all,
i'm experiencing errors in my x25/Xot env..
so i've got a HP server with a serial x25 interface connected to a cisco 2600 (c2600-i-mz.122-8.T5), thi router do XoT encapsulation and then forward packet to an other router which is connected do ***pac (itapac).
i've got this messagess (attached file.txt with wrong comunication)and i cannot understand why X25 is failing...
may anyone help me? :)
thk a lot
dani
irisrios
Level 6
Level 6
I think you need to check the default window size at the other end and set the same window size at your end. In most cases the window size is 2 so the setting of win 2 and wout 2 on interfaces should work.
