Xbox Live NAT issue 887VA
stevenr_robins
Hi All.
My router is connecting fine over ADSL but xbox is reporting moderate/strict NAT.  Has anyone come across the issue and fixed it?
Xbox is being leased an ip from routers DHCP pool (192.168.0 /24).
I believe it involves some port forwards? but cant remember how.
Seb Rupik
Hi Steven,
I'm making the assumption you have the follow interfaces configured. VLAN1 is a layer 3 VLAN on the inside of your network, and Dialer0 is connected to your ISP:
Add the following config:
interface Vlan1
  ip nat inside
interface Dialer0
  ip nat outside
...we now need to set up NAT for the XBox live ports. You need to put your XBox on a fixed IP and fill in the blank :
ip nat inside source static tcp 53 interface Dialer0 53
ip nat inside source static udp 53 interface Dialer0 53
ip nat inside source static tcp 80 interface Dialer0 80
ip nat inside source static udp 88 intrerface Dialer0 88
ip nat inside source static tcp 3074 interface Dialer0 3074
ip nat inside source static udp 3074 interface Dialer0 3074
...that should do the trick.
cheers,
Seb.
7 Replies 7
Seb Rupik
Hi Steven,
interface Vlan1
  ip nat inside
interface Dialer0
  ip nat outside
cheers,
Seb.
Thanks Seb.
I set the xbox to a static ip of 192.168.0.12 and excluded that ip from the cisco's dhcp pool.
I then applied the settings mentioned above to the config (and did a copy run start and a reload to confirm it was saved)
However still doesnt appear to work.  On xbox live connection test it reports connectivity fine but moderate/strict NAT.
Also when turning the xbox on (xbox connected to FastEthernet1 port on cisco) the interface on the cisco doesnt seem to come up quick enough to sign in to xbox live initially :/
Hi Steven,
I believe you're rerferring to UPnP feature.
I'm afraid your ISR/887 doesn't support it. This feature is usually found on SOHO type of routers (i.e. Linksys).
https://supportforums.cisco.com/thread/2178076
https://supportforums.cisco.com/thread/1004198
Hi Steven,
Try the following command:
int fa0/1
  spanning-tree portfast
...that reduce the time it takes for the swithport to come up.
Can you post the cofig of your router? There maybe an ACL somewhere blocking the traffic, and we can also configure on to see what traffic is incoming.
John, I agree that the xbox service does use uPNP, but I have seen examples of ASA configs to get this service funtional, so am sure a combination of ACLs and NAT should do the trick.
cheers,
Seb.
Hi Seb.  Config below as requested:
Router#sh run
Building configuration...
Current configuration : 2314 bytes
! Last configuration change at 12:45:54 UTC Sun Aug 4 2013
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret 4 cW5ldN/EjyvA5QrEqv8XXvWQgGAtQmiAYpmz2kK0XkI
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.0.1
ip dhcp excluded-address 192.168.0.12
ip dhcp pool HomeNetwork
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 62.24.199.13 62.24.199.23
lease 0 2
ip dhcp pool homenetwork
dns-server 192.168.0.1
ip cef
no ip domain lookup
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ17119094
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
  pppoe-client dial-pool-number 1
interface ATM0.1 point-to-point
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip mtu 1432
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname bob
ppp chap password 0 bob
ppp pap sent-username bob password 0 bob
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static tcp 192.168.0.12 53 interface Dialer0 53
ip nat inside source static udp 192.168.0.12 53 interface Dialer0 53
ip nat inside source static tcp 192.168.0.12 80 interface Dialer0 80
ip nat inside source static udp 192.168.0.12 88 interface Dialer0 88
ip nat inside source static tcp 192.168.0.12 3074 interface Dialer0 3074
ip nat inside source static udp 192.168.0.12 3074 interface Dialer0 3074
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
With the xbox switched on and attempting to connect, what is the output of 'sh ip nat trans' ?
Seb - It worked - thanks for all your help.
