Hi all,
I have a very big problem. I have configured a 3600 Cisco router with X.25 hunt-group to loadbalance traffic on several X.25 line. On the LAN side, i have configured XOT to transport X.25 over TCP till our mainframe. On the same router, i have also configurated SNAsw to transport SNI and QLLC traffic.
This configuration works , therefore i have a problem of performance. When the mainframe send a X25 call, it is OK. But when the mainframe send 2 or more simultaneous X.25 flows, the router drop X.25 flows.
In X.25 debug, i receive Code 3 diag 65 X25 status when i dont use the X25 security statement on interface. And it is OK for one X25 call. If start 2 simultaneous X25 call, i receive Code 13 diag 64 ( clear problem).
Here in copy show tech and log .
should i enter:
x25 routing use-tcp-if-defs*
and put hold-queue to 60000 in/out?
Are Cisco routers only limited to nvc 8?
Any ideas?
