Application-aware-routing is not working well
Ha Dao
Hi guys
I am using version 20.1.6, with cEdge ISR4331. I deploy AAR follow this guide:
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-application-aware-routing-deploy-guide.html#ProcessMonitortheWANtransportpathcharacteristics
My policy is prefer windows share file (dest port 445) on Internet tunnel.
But I see speed of copy is very slow and not stable (although I see that traffic seems only pass through Internet tunnel). When I try to shutdown the MPLS tunnel Interface then speed is good:
Do you have any idea for my situation. Tks
without knowing configuration (especially policy) it is hard determine where is problem. SLA class information and exact path quality values of tunnels should be given as well.
regards,
HTH,
Hi Kanan
I add policy traffic rule like this:
And you can see in my original post, I also simulate the traffic path, it only went through the biz-Internet tunnel.
It is hard to get really helpful answer in Cisco SDWAN section.
