Can I have different templates (cEdges and vEdges) for the same VPN ?
alex4572
I have cEdges and vEdges different templates as they are per device, but even though they share the same VPN number I could not see the routes from cEdges on vEdges and viceersa,  both have OMP advertised enabled and central policy allowing that kind of traffic.
Yes, you can create one VPN feature template for vEdge and another for cEdge even though it's a same vpn number. Generally it is not required, unless you want to have totally different configurations.
What is your service side routing protocol on both ends? Ensure you advertise them under OMP and also redistribute omp for service side.
Srikanth
