Cisco SD-WAN : Interface Historical Data
RS19
Level 7
Level 7
In my SD-WAN environment ASR1001-X, when checked under Monitor -> Interface via vManage WebGUI only real time data is shown.
When checked for the historical data, it shows "No Data To Display
Wanted to understand what is the reason for this & how to check this ? What needs to be done to enable the historical data to be seen
Hi, RS19.
Please check below things.
  • Total assignment and disk used in Administration > Settings > Statistics Database Configuration section exceed the Maximum Available Space limit specified at the top of the section; in those cases, the Total Space is flagged in red color as a warning message.
  • /opt/data partition exceeds 80% of usage.
  • Collection Interval(minute) is set to less than 30 minutes.
  • Analytics Only is selected in Administration > Settings > Statistics Settings for the selected feature, so data is only visible on vAnalytics.
Link : https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/220477-troubleshoot-statistics-database-and-dis.html
Thank you.
Please remark this as a solution If this is helpful.
Hi, RS19.
Thank you.
