Cisco SD WAN Licensing
Inder Singh
I have 10 SD-WAN routers with following DNA license
5 router - 100 MB license - Aggregate bandwidth on each router 70 MB
2 router - 50 MB license - Aggregate bandwidth on each router 40 MB
3 router - 20 MB license - Aggregate bandwidth on each router 15 MB
How to check which bandwidth license is associated with which router and suppose if I upgrade the bandwidth from 15MB to 50 MB without upgrading Bandwidth license then what will happen?
RohitRaj03827
You check from vManage Dashboard,
There is section called transport Interface Distribution. where you can verify.
I have attached the screenshot as well.
If you find this answer has helped you then please mark this post as a helpful and solved.
feel free to post you doubts.
Rohit Raj
Rohit Raj
