Cisco SDWAN ZTP on-prem for CEdge
Amr.Younes
Hello All,
I've tried to on-board a cEdge using ZTP on-prem, as it should be working on cEdges  IOS  17.3.1a & vManage IOS 20.3.1
Exact steps are followed using below links
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/sdwan-xe-gs-book/hardware-and-software-installation.html#Cisco_Concept.dita_a8f8f4d0-8765-4786-93c3-562e6e592ad2
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/sdwan-xe-gs-book/cisco-sd-wan-overlay-network-bringup.html#c_Start_the_Enterprise_ZTP_Server_7841.xml
cEdge IOS: 17.03.4a
vmanage: 20.3.4
cEdge has already resolved devicehelper.cisco.com. but it is not able to connect to it, seems HTTPS is not supported for the vBond acting as ZTP
*Sep 14 10:55:23.555: %PNP-6-PNP_CCO_SERVER_IP_RESOLVED: CCO server (devicehelper.cisco.com.) resolved to ip (1.1.0.156) by (pid=651, pname=PnP Agent Discovery, time=10:55:23 UTC Tue Sep 14 2021)
*Sep 14 10:55:23.555: %PNP-6-HTTP_CONNECTING: PnP Discovery trying to connect to PnP server (https://devicehelper.cisco.com.:443/pnp/HELLO)
*Sep 14 10:55:45.622: %PNP-3-PNP_HTTP_TIMED_OUT: PnP HTTP timed out (1/10) on connection to PnP server (https://devicehelper.cisco.com.:443/pnp/HELLO)
*Sep 14 10:56:15.687: %PNP-3-PNP_HTTP_TIMED_OUT: PnP HTTP timed out (2/10) on connection to PnP server (https://devicehelper.cisco.com.:443/pnp/HELLO)
Any suggestions ?
jonatan.cavaco
Hi, can you do ping from the cEdge to the vBond?
omamenko
To run local ZTP server for cEdge you need to meet next requirements:
1) DHCP-server must provide a DNS domain name (option 15) to cEdge;
2) DHCP-server must not provide option 43 to cEdge (default configuration);
3) DHCP-server must provide IP-address of DNS-server (option 6) to cEdge;
4) DNS-server must resolve ztp.local.domain (where local.domain provided in #1) to IP-address of ZTP-server;
5) ZTP-server must have uploaded valid list of cEdges in JSON format;
6) Communication between cEdge and On-prem ZTP-server is based on UDP/12346 (not HTTP or HTTPS which are used in PnP scenarios).
To verify if your configuration meet requirements:
1) Check if cEdge is provided with DNS name via DHCP - run on cEdge
cEdge# show dhcp server
2) Check if cEdge is able to resolve ZTP-server and it is reachable
cEdge# ping ztp.local.domain
3) Check if ZTP-server has valid ZTP-entries
vBond-ZTP# show ztp entries
Make sure that vBond IP (or FQDN) is reachable (resolvable), NAME field is the same as ORG Name, ROOT CERT PATH field is not empty.
4) Run tcp-dump on ZTP-server. You should see UDP/12346 (not HTTP/S) traffic from cEdge
vBond-ZTP# tcpdump interface ge0/0 | include $IP-cEdge
Hope it helps
