11-07-2025 09:50 PM - edited 11-07-2025 09:51 PM
I am running CML 2.8.1 and I cannot get the vManage GUI to work for some reason. I get the following error:
I checked that the file is missing:
Does anyone know why this happened, and how to fix this?
Juan
11-08-2025 12:14 AM
What kind of resources do you have in CML?
are you trying https://vmanage:8443
I have not encountered any issues when I set up a Lab.
https://www.balajibandi.com/?p=2028
11-08-2025 02:52 AM
I have the SD-WAN supplemental ISO, and I am using the lab nodes...
When I do netstat -tln I only see the vManage listening on port TCP 22 and 830, not on 443 or 8443...
And also, the vEdge gives this issue:
Any one having similar issues?
11-08-2025 03:52 AM
11-08-2025 04:13 AM
Do you mean VM resources? I have the CML VM with 16 vCPUs and 64 G of RAM.
The vManage takes 8 vCPUs and 32 G of RAM...
11-08-2025 09:41 AM
Are you only running Vmanage as a single node in CML, or are you using other resources that consume all the compute? You can see how much resource is left in CML at the bottom.
I have run before with 2.8, and it works as expected. Additionally, using 2.9, VML SD-WAN VManager works as expected.
We encounter these issues: either the image is not copied as expected, or there is a general resource issue; otherwise, everything works as expected.
