Determining Control Connections Source and Destination Interfaces
slafr01@ca.com
Problem: Unable to determine the Source Interface for a control connection.
Below is the sample Control Connection output from the api call: https://VMANAGE-
IP:PORT/dataservice/data/device/state/ControlConnection
In the above control connection example, we are unable to determine the source and destination interfaces based on the color as one device has different interfaces for the same color.
For example vdevice-name: 1.1.1.5 which is a vmanage has 8 instances of same interface with same color. How do we determine the interface which is actually used by the control connection here?
Same goes with the destination interface as well.
Fred
0 Replies 0
