new to networking. Help with pinging across a network
I am finding it impossible to ping across my network. I am extremely new to packet tracer and networking as a whole so i apologies if my question seems silly. I can ping between devices within each LAN individually. But i am unable for example to ping 192.186.1.3 from PC 192.168.0.3. when completing this command i am getting " destination host unreachable.
I think my mistake has something to do with my input for the routers RIP which is as follows:
192.168.0.0
192.168.1.0
192.168.2.0
192.168.3.0
192.168.4.0
192.168.5.0
192.168.6.0
192.168.8.0
192.168.9.0
192.168.11.0
192.168.0.0
default gateway is 192.168.0.1
192.168.1.0
default gateway is
192.168.1.1
and so on
sdipippo
Hi dainatarleton33244,
Welcome to networking!
Try a traceroute from the PC0 ("tracert 192.168.1.2") and see where it stops. That will give you an indication about where the problem is, and you can then hone-in on that spot to continue troubleshooting.
Hope it helps!
Steve
