How to apply ACL for line vty cisco SDWAN XE
David Du
Hi there, I am looking to compose a policy to force ACL to line VTY on SDWAN routers
vManager -> Policies -> Access Control List Policy -> Add IPv4 Device Access Policy -> Add ACL Sequence
But when I apply it to the template:
Device Templates -> Additional Templates -> Policy (Choose ACL policy name)
I can see the ACL can be created on running-configure but in line vty it doesn't map that ACL such as:
line vty 0 4
access-class ......
Please anyone can guide me on what should I do next?
vManager ver 20.9.3.2
areidy
Hi David, it should be a 3 step process
  1. Create the Device ACL (Policies --> Custom Options --> ACLs --> Add Device Access Policy - Add IPv4 Device Access Policy)
  2. Apply the Device ACL to your Local Policy (LP --> Select /Edit required Local Policy --> Select Access Control Lists tab --> Add Device Access Policy --> Import Existing --> select your DACL)
  3. Apply the Local Policy to your Device Template
