07-02-2025 02:35 AM
i've got a (retro)lab and try to understand fundamentals, recreate configurations etc.
Basically it's a 3845 with several interface types (in this case relevant: VWIC-2MFT-E1 and VIC2-2BRI-NT/TE)
I connected a isdn device (fritzcard usb) to one of the BRI-ports in NT-mode.
I connected my as5350 to one of the PRI-ports.
Dialing via SIP (or the VIC3-4FXS) over the 3845 into the AS5350 with a modem works fine and the sessions are terminated.
But dialing via ISDN lets the 3845 answer the calls and try to terminate the ppp session directly.
How can i instruct the 3845 to route ALL calls to a defined number to the AS5350?
Or the other way around: What makes the 3845 accept datacalls instead of forwarding them to the dial-peer?
Kind regards
Stephan
07-02-2025 04:29 AM
When i make a PPP call from another E1 line into the 3845 it gets properly routed to the AS5350.
So it seems it has something to do with the config of the BRI ports.
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn layer1-emulate network
isdn sending-complete
isdn skipsend-idverify
line-power
interface BRI0/2/1
no ip address
line-power
voice-port 0/2/0
no vad
compand-type a-law
cptone DE
voice-port 0/2/1
no vad
compand-type a-law
cptone DE
I can't find any specific config that makes the BRI-ports answer datacalls.
07-02-2025 04:39 AM
After defining a dial-peer for the bri-port, the calls get routed.
I also removed several residues from my original ppp-config (i used the 3845 as a ppp dialin router before i got the AS5350 - because i was unable to get digital modem (mica) cards for the 3845 somewhere for a fair price)
dial-peer voice 4000 pots
description ISDN Port 0
destination-pattern 4000
no digit-strip
port 0/2/0
dial-peer voice 4001 pots
description ISDN Port 1
destination-pattern 4001
no digit-strip
port 0/2/1
dial-peer voice 3000 pots
description AS5350 Inbound Calls
destination-pattern 3000
no digit-strip
port 0/1/1:15
dial-peer voice 3001 pots
description AS5350 BBS
destination-pattern 3001
no digit-strip
port 0/1/1:15
