How to understand Decrypt, No Decrypt or Pass Through option ?
How to understand Decrypt, No Decrypt or Pass Through option in Cisco SDWAN TLS/SSL Profile?
If you choose URLs, enter the following:
VPNs
TLS/SSL profile.
Enter a name for the profile.
Choose Decrypt, No Decrypt or Pass Through. Alternatively, you can choose multiple categories and set the action for all of them using the actions drop-down menu.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/security/ios-xe-17/security-book-xe/m-ssl-proxy.html
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
  • drop: If the verdict is drop, the hello packet from the client is dropped and the connection is reset.
  • do-not-decrypt: If the verdict is do-not-decrypt, the hello packet bypasses TLS proxy.
  • decrypt: If the verdict is decrypt, the packet is forwarded to the client and goes through the following:
TCP optimization for optimization of traffic
Decryption of encrypted traffic through TLS proxy
Threat inspection through UTD
Re-encryption of decrypted traffic through TLS proxy
Note
If there is a delay in determining the decrypt status of the flow, the UTD configuration for fail-decrypt is exercised.
Note
