Hybrid Environment Meraki MX and Switch Catalyst 3560
Marcos Rogério
Hi Everyone,
I am working to install a Meraki MX in an existing environment, We use a segregation LAN with a switch cisco catalyst 3560. There is a domain controller and desktops. The diagram is: Internet link <> Meraki mx <> Switch catalyst 3560 <> Lan with AD end desktops. My gateway network is the Catalyt L3.
When I applied the policy from Meraki MX is work well, but if I got uses information from active directory the information not working well.
I would like to know if is there any incompatibility with this environment?
I am going to appreciate this information.
Thank you for your time.
Best Regards.
Hello
I assume you have you successfully tested the AD authentication from the MX and if so what exactly isn't working?
res
Paul
Kind Regards
Paul
