IOS XE 16.12.2r not supported in isr for sdwan
Dears,
It is to inform that i am installing ios xe 16.12.2r on isr4321 but while boor process it shows message that "ios not supported 16.12.2r" . What could be reason and how i can resolve it?? Waiting for reply and thanks
BR:
15 Replies 15
How are you upgrading, vManage or CLI?
I mean, that release IS supported. What image are you upgrading from?
I would create a TAC ticket as well.
Dear gilbert,
First of all thanks for your reply. Below is answer to your query.
- Through CLI. Console cable. I didn't add it in Vmanage. This is second step,       first need to upgrade IOS-XE for sd wan
- I am upgrading from isr4300-universalk9.16.03.06.SPA.bin
If you need more information, please ask to resolve this issue. Thanks
BR:
Kamran
john.nield1
Do you have a compatible ROMmon version? What version of ROMmon and IOS-XE SD-WAN are you running currently The release notes state you need 16.12.(1r) https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/xe-16-12/ios-xe-sd-wan-re-notes-16-12.html#id_110106
Dear Gilbert,
- no its not compatible, its ROMmon ver is 15.4(3r). I tried to upgrade it to 16.12.2(r) as per recommendation but its also failed to upgrade.
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/release/xe-16-12/isr4k-rel-notes-xe-16-12.html
What version of ROMmon and IOS-XE SD-WAN are you running currently.
Current is  ROMmon ver is 15.4(3r) and IOS-XE SD-WAN is 16.12(2r).
BR:
Kamran
Dear,
According to below matrix, i should install 16.9.4 ios xe and rommon 16.7(5r) because my controllers have 18.3.4 software version??? Thanks
Compatibility Matrix
Table 10. Compatibility MatrixControllersENCS/ISR/ASRISRv
18.3.5
16.9.4
16.9.4 with NFVIS 3.9.1FC1 or NFVIS 3.9.2-FC4
18.4.0
16.10.1
16.10.1 with NFVIS 3.9.1FC1 or NFVIS 3.9.2-FC4
19.1.0
16.11.1a
16.11.1a with NFVIS 3.9.1FC1 or NFVIS 3.9.2-FC4
19.2.0
16.12.1b
ROMmon Requirements Matrix
The following table lists the minimum ROMmon versions supported on the corresponding devices and releases:
Table 11. ROMmon VersionsDeviceROMmon Version for 16.10 DevicesROMmon Version for 16.11 DevicesROMmon Version for 16.12 Devices
ASR1000-X/HX
16.3(2r)
16.3(2r)
ASR1001-HX, ASR1002-HX, ASR1001-X: 16.9(4r
ASR1002-X: 16.7(1r)
ISR 4000
16.7(4r)
16.7(4r)
16.12(1r)
ISR 1000
16.9(1r)
16.9(1r)
16.12(1r)
Table 12. Recommended Rommon Release for SD-WAN for Cisco ISR 4000 series Integrated Services Routers (Cisco ISR 4000)Cisco IOS XE ReleaseCisco 4321 ISRCisco 4321 ISRCisco 4331 ISRCisco 4351 ISRCisco 4431 ISRCisco 4451 ISRCisco 4461 ISR
Cisco IOS XE 16.9.x
16.7(5r)
16.7(5r)
16.7(5r)
16.7(5r)
Cisco IOS XE 16.10.x
16.7(5r)
16.7(5r)
16.7(5r)
16.7(5r)
16.7(5r)
16.7(5r)
Cisco IOS XE 16.11.x
16.7(5r)
16.7(5r)
16.7(5r)
16.7(5r)
16.12(2r
16.12(2r)
Cisco IOS XE 16.12.x
16.12(2r)
16.12(2r)
16.12(2r)
16.12(2r)
16.12(2r)
16.12(2r)
16.12(2r
Okay, I think you should maybe upgrade to a earlier version, and then upgrade to release 16.12.2r once you have the router in vManage.
When I purchased my ISRs, there were a few that had boot loader issues, and failed to load any image. So, right out the box, I was able to add image, "isr4300-ucmk9.16.12.1d.SPA.bin" to get it working and syncing with vManage.
So try image "isr4300-ucmk9.16.12.1d.SPA.bin" and let me know what happens.
Dear Gilbert,
Unfortunately, old ios removed mistakenly. now router in rommom mode. From here, how i can upload new ios xe ver which u suggested (16.12.1d)?? I tried through serial com port securecrt xmodem but in vain. The error i got while selecting xmodem( send or receive ) is attached. Kindly can u support me how i can upload new version in rommon mode.
Secondly when i applied command >set (in rommon mode), in output i can see old version ios xe there. can i boot it from here??
BR:
Dears,
I used below technique to upload ios in router in rommom mode through tftp. But tftp opoeration aborted bcesuse link between PC and router didnt comeup.
"Interface link did not come up. Timed out."
Why  link is not coming up??? i connected ethernet onr by one to GE0/0/0, GE0/0/1 and MGMT ports but link is not coming up. whats the reason??
rommon 12 > boot tftp:isr4300-ucmk9.16.12.1d.SPA.bin
IP_ADDRESS: 10.10.10.1
IP_SUBNET_MASK: 255.255.255.252
DEFAULT_GATEWAY: 10.10.10.2
TFTP_SERVER: 10.10.10.2
TFTP_FILE: isr4300-ucmk9.16.12.1d.SPA.bin
TFTP_MACADDR: f0:7f:06:ca:ad:7f
TFTP_VERBOSE: Progress
TFTP_RETRY_COUNT: 18
TFTP_TIMEOUT: 7200
TFTP_BLKSIZE: 512
TFTP_CHECKSUM: Yes
ETHER_PORT: 1
ETHER_SPEED_MODE: 1000MB/FD
TFTP: Operation terminated.
boot: netboot failed
rommon 13 >
BR:
Dear,
After connected ethernet cable to MGMT port of router, link came up and tftp operated but image failed to run. what is the issue??? Why this happened... check the below output.
rommon 1 > boot tftp:isr4300-ucmk9.16.12.1d.SPA.bin
TFTP_TIMEOUT: 7200
TFTP_BLKSIZE: 512
TFTP_CHECKSUM: Yes
ETHER_PORT: 1
link up
Receiving isr4300-ucmk9.16.12.1d.SPA.bin from 10.10.10.2
File reception completed.
Boot image size = 0 (0x0) bytes
application image failed to run
rommon 2 > confreg
BR:
Dear support,
Second method i used to boot ios from USB but its also not working. below is output: what could be reason and how can boot from usb??
rommon 3 > boot usb0:
Located ~$Alain OZAN unlocking v7.pptx, start cluster is 6
Image loaded
Boot image size = 165 (0xa5) bytes
Unknown image structure
Located isr4300-ucmk9.16.12.1d.SPA.bin, start cluster is 0
Invalid cluster# 0
Unable to load image :isr4300-ucmk9.16.12.1d.SPA.bin
Unable to load isr4300-ucmk9.16.12.1d.SPA.bin
Located .dropbox.device, start cluster is 917529
Image loaded
Boot image size = 56 (0x38) bytes
Unsigned package found, aborting ...
Located ~$Wireless Project Report.xlsx, start cluster is 66461
Image loaded
boot: cannot determine first file name on device "usb0:/"
rommon 4 >
So I would only suggest booting image from usb, but these routers are VERY picky on the type of USB you use. I had multiple brand new USBs formatted the same and only one worked, so hopefully you have one that reads.
Can you do a "dir usb0:" to make sure the router can read the USB? Hopefully you see the image in there. Should look like this:
rommon 1 > dir usb0:
0   0         drw-     System Volume Information
0   582589532 -rw-     isr4300-ucmk9.16.12.1d.SPA.bin  << this entry shows the router can read the USB and the image.
Now boot from USB:
rommon 1 > boot usb0:isr4300-ucmk9.16.12.1d.SPA.bin
Let me know if you have problems.
Dear Gilbert,
USB is readable but still image did not boot. See below outputs. Need your suggestions. Thanks
rommon 3 > dir usb0:
File System: FAT32
3 0 drw- System Volume Information
65538 0 drw- .Trashes
65540 0 drw- .Spotlight-V100
6 165 -rw- ~$Alain OZAN unlocking v7.pptx
0 0 -rw- isr4300-ucmk9.16.12.1d.SPA.bin
917529 56 -rw- .dropbox.device
66461 165 -rw- ~$Wireless Project Report.xlsx
7 0 drw- Kamran
118038 0 drw- My data
rommon 4 >
rommon 4 >
rommon 4 > boot usb0:isr4300-ucmk9.16.12.1d.SPA.bin
Invalid cluster# 0
boot: error executing "boot usb0:isr4300-ucmk9.16.12.1d.SPA.bin"
rommon 5 >
rommon 5 >
BR:
  1.  Power cycle the router and force it into rommon with break sequence (ctrl+break, ctrl+c) or use the Break option on Putty or SecureCRT
  2. Change the config register to 0xA102 to bypass configuration.
    rommon 1 >     confreg 0xA102
    You must reset or power cycle for new config to take effect
  3. reset
    rommon 2 > i
  4. Make sure to "Break" the boot so we can expedite the process and move on to Step 5, otherwise we would need to let the boot-loop for another 5-10 minutes.
  5. Now boot from USB:
    Firmware will try to upgrade, "break" the process and retry booting from usb until the image loads. When you do get to load the image from USB again, let the process work. If you get to a boot-loop again, just break again, rinse and repeat until the image FULLY loads.
  6. If this doesn't work then I would RMA the device.
  7. Also make sure you have the required hardware enough to run an SD-WAN image.
Dear,
I follow the below steps but in vain. Can you write down hardware requirement to run sdwan image?? just to double check.
Also can i install isr4321 old ios xe image though usb then i can try to update it to sdwan image??
BR"
