IOX-XE SD-WAN Availability on ISR 4400 Platforms
wilton.white
Is there a roadmap which identifies a date that has been set for the release of the IOS-XE SD-WAN image on the ISR 4400 (4431, etc.) series routers?  The image is already available for download and use on many of the ISR 4300 series routers.
Page 19 of the following document cites the availability of a roadmap, but it does not provide the location:  https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise-networks/sd-wan/white-paper-c11-741071.pdf
Thank you.
kumaamit
This will be out in the next release, there is no official documentation yet regarding this. We do have support for IWAN for 4431 and 4451,
but no document for SDWAN part. With next release of IOSXE release mostly would include these routers. Do keep in sync with SAC if any updates
we will let you know. In meantime, if you do not have further questions can I close the case.
kumaamit
