ISR 4K as vEdge
I want to know if a ISR 4K Router work as vedge. Any license is required?
If we want to buy a ISR 4331 & 4431 router work as viptela vedge, how can we prepare the bom? any ordering guide?
amcastagna
Thanks for the reply @amcastagna
but I'm still not sure how to make ISR4K router work as vEdge?
I'm not sure if using this SKU : ISR4331-DNA will make it work as vEdge
Please take a look here: https://youtu.be/qugfIlEmSEM
Just to make sure we are on the same page, loading IOS XE SDWAN image on ISR4K does not technically turn it into vEdge. Both vEdge and ISR4K are offered as SD-WAN edge routers.
Hope this helps.
David
Twitter: @DavidKlebanov
Farhan Mohamed
Yes, you can manage vEdge using vManage, and yes there is license required for that. If customer wants to also manage ISR devices through vManage, he would purchase the ISR and port the license from vEdge to ISR. For Example: Cisco ONE WAN Foundation license
Simple add C1 wan foundation license to the BOM.
