ISR4331 SD-WAN Code Supported Modules
d2a
Hi, does anyone know if the below link is the most complete list of supported modules for the ISR4XXXs running SD-WAN code?We currently have a number of ISR4331 with internal Ethernet modules (SM-X-ES3-16-P). We are only going through the planning stage at the moment and I am looking at the hardware that we have and what we can reuse and I can't see the internal switch module being supported. I guess if it's not there then it's a no, just wanted to see if anything has experience with these modules.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/xe-17-3/sd-wan-rel-notes-xe-17-3.html#reference_db4_fbk_mmb
inderdeeps
Level 4
Level 4
Yes this is the correct link.
Inderdeep Singh
www.thenetworkdna.com
