ISR4451 + SD WAN
RS19
Level 4
Level 4
I have the below Cisco ISR router in my environment.
Cisco ISR4451-X/K9 running Cisco IOS XE Software, Version 16.06.06
Would like to know if this router can be used as SD-WAN router by changing the IOS router to SD-WAN IOS ?
Does this router model can be converted to SD-WAN device ?
HashamM
ISR 4451 is supported for SD-WAN. See the hardware compatibility matrix here
https://www.cisco.com/c/en/us/solutions/enterprise-networks/sd-wan/compatibility-matrix.html
In the data sheet regarding performance of ISR 4451 router the below is mentioned
Encryption throughput (Internet MIX)   2 Gbps
Could you please let me know what does that means ?
Encryption throughput - Is it IPSec throughput ?
What is Internet MIX means ?
Input traffic + output traffic
