Issue creating Template with 2 Public Interfaces
Cormac Champion
Hi all,
I'm working with Viptela Templates for an ISR-1100 and I want to create two external interfaces - one with DHCP (a default and fallback interface) g0/0 and one with a STATIC IP g0/3.  I want to preconfigure a STATIC port while I'm on DHCP.
However, when I tried and pushed the config, I got the error "Only one tunnel-interface with color "default" allowed"
How can I achieve what I need ?
maxnpj
In the "VPN Interface Ethernet" template of one of the interfaces; under the "Tunnel" section change the color from "default" to something else.....anything else. For me, when using two broadband connections I use the "public-internet" color for one interface and then "biz-internet" for the other interface.
So using your interfaces as an example, "g0/0" would use the tunnel color "public-internet" and "g0/3" would use the tunnel color "biz-internet".
