Loopback not working in underlay vEdge Device.
amangoel9
I am trying to ping Loopback interface IP from PE Router in Underlay SDWAN vpn 0. But its not Pinging from either side.
we are using Static Routing between PE and vEdge.
is there anything special we need to do?
David Aicher
did you change the tunnel interface config to "allow-service icmp".    The implicit ACLwill block you otherwise.
