Mixing ISR and ASR in Cisco IWAN Hub Level
thewifidude
We are in the process of graduating to Cisco's SD-WAN(Viptela) but in the meantime we have Cisco IWAN. Currently our internet hub router (ISR4451) is exceeding the performance 2Gb license. All routers at the hub level are ISR4451. Is it okay to mix one of them with an ASR?
When you say mix, you mean have ISRs and ASRs on different ends of the SDWAN tunnel? If so, it is ok.
ASR1002HX is a very good option for Data Center whilst ISR4451 is a very good option for branches.
