11-17-2022 10:45 AM
Hi all,
just want to know the procedure to add new edge device in Viptela SDWAN network --please check.
1.Company has smart account with Cisco and When we add new device in McKesson that Device is also get registered in smart account with serial number and Vmanage can know about this device from below option--
1.Upload WAN edge list--how it happens
2.Export Bootstrap Configuration---How it happens
3.Sync smart account--How it happens
then VM tell about this device to Vbond and Vsmart ,right?
11-18-2022 04:32 AM
There is a very detailed documentation on the onboarding procedure where we can find answers about your questions on the Appendix.
To answer shortly to your questions
When your devices are on the vManage it sync with vBond and vSmart. Your vBond acts as first entry authentication and if you have cli access you can use the command
show orchestrator valid-vedges
to verify what edges are valid, chassis-number, serial number, org etc..
I hope my answers helped you.
Best Regards
Anestis
