vManage 20.3.5 API issues
Octaviusss
I am using vmanage 20.3.5. I was on 19.2.3 early
The issue is with vmanage api, where it errors out with ‘max retries exceeded’ with GET and POST. The issue is intermittent, it is a hit or a miss. I use the code mentioned in the devnet to access vmanage api
Should we reuse the session and token if we are calling it from a front end each time? This has been causing a lot of issues with response not getting back most times
0 Replies 0
