OMP route redistribution into BGP
Tim_J_RC
I have a question about route redistribution from OMP to BGP.   It appears that routes redistributed from OMP to BGP have their metric set to 1000 and local-pref set to 50.
bgp routes-table vpn 201 10.100.106.0/24
info 0
nexthop 0.0.0.0
metric 1000
local-pref 50
weight 0
origin incomplete
as-path 65030
path-status valid,best
tag 0
ospf-tag 0
Now, I didnt set those, so it's being done automatically.  Where can I change this?   I think it's impacting my routing, and need to make a vSmart advertised route prefered over the route learned from the local side of the vEdge.   Thanks.
manuelosorio
Hi @Tim_J_RC
To modify the BGP attributes, a Localized Control Policy must be created.
Configuration > Policies > Localized Policy and click on Add Policy.
Match:   Prefix list
Actions : Local Preference
Then,  it must be applied to the template associated with the Wan Edge.
Templaste > Adicional Templastes > Policy
<< Mark as helpful or answered, if the answer resolved the question, this helps future requests from other members of the community >>
create local control policy and route policy (basically, route-map) inside it. Attach local control policy to device template, and refer to route policy name in BGP template.
HTH,
