Org Name and Serial number in the AvNET Certificate for hardware vEdges
muthumohan
I know that Cisco installs an identity certificate on hardware vEdge routers (in tamper proof module) by AvNET at the time of manufacturing it. I have a couple of questions about this:
1. Does this certificate include the Organization Name to which it will be shipped later on?
Why I am asking this is, when the controllers authenticate this vEdge, they will verify the organization name on vEdge's cert. So, I am guessing that Cisco includes the Organization Name in the AvNET certificate. Correct me if I am wrong.
2. Does the serial number of the certificate match the serial number of the router (on the box)?
As per the documentation, the verification happens based on 'certificate serial number' and not on actual serial number on the box. Or, are they same? Do they put the box's serial number in the certificate?
3. On the WAN Edge serial number list, does it contain the "certificate serial number" or the box's serial number?
Thank you,
Mohan
Hello ,
1) controllers don't verify org name of vEdges, but vEdges do for controllers (Btw, controllers check each order's org_name as well).
See "Authentication between Cisco vBond Orchestrator and a vEdge Router" section:
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/sdwan-xe-gs-book/cisco-sd-wan-overlay-network-bringup.html
2) For IOS XE devices there are 2 serial numbers that used before 17.3. One is "SUDI serial number", another is "Certificate Serial Number". You had to know both and to PNP portal (sometimes automatically SUDI &PID are added, but not cert number).
See "Procedure 3: Add WAN Edge devices to the portal" section :
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/SDWAN/cisco-sd-wan-certificates-deploy-2020aug.pdf
Beginning 17.3 ,Cisco removes cert serial number requirement, so basically PID and SUDI serial are needed.
See "Remove Certificate SUDI requirement." section :
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/xe-17-3/sd-wan-rel-notes-xe-17-3.html
I don't believe they are the same (device SN and certificate SN). I'm not "guru" in PKI, but most probably SN for certificate is automatically generated.
3) Certificate list (basically white list for controllers) don't include hardware (box) SN. See answer 2.
HTH,
Hello ,
HTH,
