Question about deploying a remote WAN edge into a SD-WAN fabric already in production
HI,
I am newby on SD-WAN...
I don't have a SD-wan production, but i have read several documents and have doing some test with my own lab.
I have a question... let's say i have a production sd-wan fabric working, all controller on-premise on my HQ, with public IP address, and have 5 WAN Edges already working, hub-spoke, if i need to add to the fabric one more WAN Edge, using manual provisioning, this site will have static public IP, so that will be configured on the interface for VPN 0 transport (enabling the tunnel interface) of the new WAN Edge, and then i will have to execute the command: "request vedge-cloud activate chassis-number XXXXXXXXXX token XXXXXXXXXXX"
then i will need to download the CA root cert,
The only way to download it, is using the vpn 512?. can i use a service vpn? (suppose vpn 512 has public IP address, if not i could use NAT on transport VPN). I understand that i can't use the vpn 0 because of the ipsec encapsulation is enabled, and the WAN Edge is not on the fabric yet, I am a little confuse here...
please your help,
best regards,
Juan Pablo
Octavian Szolga
Level 4
Level 4
Hi Juan,
You can copy any file from a server to any WAN Edge router as long as you haven't applied the tunnel-interface command on the WAN interface because that will actually harden the interface - i.e. allowing only a specific set of protocols like DTLS, ICMP, DNS, and others (FTP/SCP/TFTP are not on the list and cannot be allowed).
Long story short, if I remember correctly, you need "request vedge-cloud activate chassis-number XXXXXXXXXX token XXXXXXXXXXX" command only if you're using virtual devices (ISRv, CSR1000v, Cloud vEdge) or ASR1002-X which don't have SUDI/TPM certs.
As an alternative, you can always copy the root CA over a USB stick and install it afterwards.
Another option would be to generate the bootstrap file from vManage. The bootstrap file will contain the root CA as well.
BR,
Octavian
