RBAC - SSO and Scopes
pawzg
I am using SD-WAN Manager 20.15.3.1. I have configured SSO to access it via GUI. Users belonging to different groups are associated with a proper role after successful logon.  I would like to use scope mechanism now however I have no idea how to link ad group or role with a scope prepared by me. Does anyone know how to proceed? Thanks!
Cristian Matei
    Check this document and look for "Information About Assigning Roles Locally to a User Defined by an Identity Provider. It works with both getting the role from IdP as well as defining the role locally.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/ios-xe-17/systems-interfaces-book-xe-sdwan/m-rbac-17-13.html
Cristian.
Thanks for feedback but this not solves the problem. Roles assign process for user groups works perfectly fine for me and I gets the roles from IdP. However I have a problem with assigning Scopes to the user groups. It may be the CSCwo62038 bug, but I am not sure.
  You don't know how to perform the configuration or configuration is done right however it doesn't get enforced upon user authentication? Did you add the user as a remote user and attached the configured scope?
Cristian.
Cristian.
