Regarding sdwan omp syntax "advertise bgp route-map test"
maazsiddiqui
Hi Everyone
I want to advertise the BGP route map in OMP. I am confused that whether the below syntax will work or not in the ios xe version 17.09.04 special this one "advertise bgp route-map test"
omp
  no shutdown
  ecmp-limit 6
  graceful-restart
  no as-dot-notation
  timers
   holdtime 300
   graceful-restart-timer 120
  exit
  address-family ipv4
   advertise connected
   advertise static
7 Replies 7
balaji.bandi
as per syntax that should work, have you tested and any issue ?
refer the document as below :
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/routing/ios-xe-17/routing-book-xe/m-unicast-routing.html
BB
We are not getting any option to redistribute bgp with the route map in the OMP feature template , however we can see the option to use route map when redistributing omp into bgp in BGP feature template.
But cedge in cli mode accepting the command.
"Advertise bgp route-map test"
But not sure it'll work or not
Friend
OMP ->> BGP we use redistrubte
BGP ->> OMP we use advertise
It two way
MHM
Yes, You are right.
But there is no option available to advertise specific prefixes from BGP into OMP, However if you check the BGP or OSPF feature template you will get the route policy option to redistribute specific prefixes.
So how can we advertise specific prefixes from BGP to OMP , using cli template(using route-map) or policy?
We have created a prefix list and route map but I read somewhere that it advertising the BGP in SD-WAN omp will not work.It will accept the syntax but won't execute according to BGP route map.
Can I see doc.
We can use local police to exclude some prefix.
MHM
