Renaming Host VPC
zekebash
I am trying to rename host vpc but it doesn't seem that there is an option to do so. I tried to Un-Map that vpc so I can re-map it and then give it the new name; however, when I tried to search for the host vpc account name it came up with the same name which I had un-mapped.
What is the best way to rename existing Host VPC?
Thanks in advance.
Best, ~zK
svemulap@cisco.com
Is this in AWS ? Can you change this on the AWS side and rediscover on the vManage ?
I was trying to do it in vMange under Configre\IAAS. I was able to delete the instance but there is no option to rename the host.
There isn't an option to rename / change host VPC in vManage.
You can map / un-map host VPCs through CoR IaaS workflow.
If not, please send screen shots with problem on what you are trying to do / accomplish.
