Replay window size and Extended Anti replay what are best practices
csco10260962
In security feature template Replay window size and Extended Anti replay what are best practices  ?
Should only one be used or both ? What are best practices. We are using normal QOS settings (not per tunnel or per vpn qos).
In logging we saw a lot of replay hmac errors. And show crypto ipsec peer x.x.x.x platform did not show window size that was configured under the feature template. Are they mutally exculsive or can they both be on at the same time ?
AshSe
@csco10260962
To directly address your question: Both features can be used together, but enabling Extended Anti-Replay is generally sufficient and recommended in most cases, especially in networks with normal QoS settings.
Best practices (normal QoS settings):
  1. Enable extended Anti-replay
  2. Monitor replay HMAC errors.
  3. Avoid configuring both features simultaneously.
  4. Use Replay WIndow size only if Anti-Replay is not configured
AshSe
