Sd-WAN max Wan Interfaces
Hiram Morlan
Hi Guys,
I have a project about Sd-WAN, some branches have 2 internet connections and 1 mpls.  Will this 3 Wan connection scenario is possible to deploy? What are the maximum Wan connections for Cisco Sd-WAN?
Thanks in advance.
Sengarth
Your posted scenario is definitely supported. Up to 8 TLOCs are supported in Cisco SD-WAN. There is no fixed "WAN" interface that you need to plug in the cable on the vEdge or cEdge, any physical port on the device can be configured as a WAN interface. WAN can also be configured on a sub-interface (VLAN-tagged).
Refer to further explanation here.
Sengarth
