SD-WAN POC Tool how to configure TLOC?
In SD-WAN POC Tool in Cisco dCloud I want to configure a TLOC extension between vEdges but I can't find any documentation or demo's how. Could someone explain me how to do it?
Thanks.
osdesent
it's pretty straigh forward, just make sure to use vmxnet driver's interfaces on the c/vEdges
Oscar Desentis
Customer Success Specialist (SD-WAN)
@osdesent but I mean, what do I have to enter in the fields on the screenshot below? I haven't assigned any IP-addresses, so what do I have to enter as IP Address on vEdge1 and what on vEdge 2?
And what prefixes and which ge on both sides?
The POC tool provides a GUI (API based) to configure most of the appliances as you can see with the screenshot shown as an alternative to CLI. Now what you need to provide there is the TLOC configuration for that particular vEdge. So for instance, the IP itself of the ge0/1, its mask and if you want it to act as a TLOC and its TLOC ext in case it applies according your needs
Oscar Desentis
@osdesent
I currently have the following setup on a site:
So now I want to configure a TLOC between vEdge 1 and 2 and visa versa.
When I click on ge0/1 at vEdge1, do I connect it to ge0/1 at vEdge2?
