SD Wan Routing
MsmanXY
Dear all Friends,
We are use Cisco SDWAN and have two links ( path)
- Public Internet
- Biz Internet
By default, we use active/active on both links, per-flow load balancing from Branches to HQ and HQ - to Branches.
Now we want apply a policy for routing like : Some traffic, subnets ...from Branch to HQ prefer Public Internet and backup route by Biz Internet.
Please help me, how to do that, can we define branch traffic by subnet .
Thank you so much.
MsmanXY
if you want all subnet in site-A use one circuit as primary and other as backup check this
https://www.thenetworkdna.com/2021/02/the-role-of-preference-and-weight-in.html
if you want specific subnet then as I mention before use tloc-action
MHM
14 Replies 14
Thank you,
As my understand , If we use TLOC action, that mean all traffic from branch always prefer one of two links right ?
I am a newbie , Can I user AAR routing to make a policy matches source subnet of branch to destination subnet of HQ and prefer biz or pubic link ?
Thank you so much.
check my answer to Mr. @Kanan Huseynli  below
thanks
MHM
do you have full mesh tunnels between sites or you use restrict and/or tunnel group to have separate tunnels over separate TLOCs?
By default you should have not 2 but 4 (2x2) tunnels between sites:
biz - public
biz - biz
public - public
public - biz
If you use restrict / tunnel group you will have:
biz - biz
public - public
Firstly, confirm this to understand how to apply policy properly.
HTH,
I think he ask to make prefix-A in Site-A use Public
and prefix-B in Site-A use private
so he need to config policy match route and site then apply action set the tloc as primary and backup
I hope I am correct
MHM
Whatever you mentioned above is totally related to different thing. Primary/ Backup in tloc-action does not work in this way when you have direct paths only.
I understood what he wanted, but to give proper policy configuration there is need to understand existing overlay design.
HTH,
I think we can use it.
In hub and spoke we set tloc using hub IP
Here we use vedge IP and set primary
And then finally we stop advertise tloc (not omp) between vedge.
This way the vedge have only tloc receive from vsmart from it policy.
MHM
Sir, did you test "tloc-action" in lab/production environment? It totally works differently
Secondly, if you filter TLOC via policy using vSmart, how does router will switch path to the secondary if there is no tunnel between TLOCs?
HTH,
Hi Kanan Huseynli and MHM
Real , we have both links , one is 200 Mbps, and one is 500 Mbps. As I research and read, We can set TLOC prefer by weight to prefer traffic to TLOC 1 ( link  500Mbps) right ?
Can you help me how to config it, bz I am a newbie .
Thank you so much
Please, answer to the question I addressed before and also say me "do you have branch to branch" tunnels?
Depending on your overlay design, answer varies, so I'm asking this question.
Note: there are couple of ways to do, depends on your overlay design and business/technical requirements
HTH,
Dear Kanan Huseynli,
Yes, we are using overlay like :
biz - biz
public - public
Two branches , Two Internet Link per site, topology like :
Site A-----2 links-----Site B, and 04 tunnel formed
A -----Biz----B
B-----Biz----A
A-----Public---B
B----Public-----A.
Thank you so much,
Can you share below command output to understand fully,
"show bfd sessions" from branch? (or "show sdwan bfd sessions" if it is IOS XE)
HTH,
MHM
MsmanXY
Thank all you guy,  I use Weight on tunnel interface.
Regards.,
Ms
