11-26-2018 10:54 PM - edited 03-08-2019 05:32 PM
Can anybody tell about the max bandwidth supported by Cisco3925 router for SDWAN deployment?
Is there any upgrade or any way to increase the same to 500Mbps?
12-06-2018 08:23 PM
Hi Akhilv,
3925 is not supported under sd-wan edge portfolio!
Consider ISR4K series , specifically 4431 in ur case.
07-01-2020 03:51 PM
Cisco Viptela SDWAN Series
