SD-WAN
navidn
I would be appreciated if someone guides me with the following questions:
  • In the case of more than 25 vEdges deployments and for purchasing DNA subscription, is the default permitted crypto bandwidth is 250Mbps always? or, if the DNA subscription is lower than 250Mbps, that would be applied?
  • How does the bandwidth allocation apply exactly? Is it applying in the Viptela file or when vManage integrates with a smart account?
  • Does the consumed bandwidth for the LAN connection count in the Crypto bandwidth limitation? If not, how much bandwidth is allowed for different edge platforms by knowing that smart license is not supported on the controllers!
  • Is that possible to add various Viptela files on the vManage from 2 different smart accounts?
  • Is that mandatory to integrate vManage with the Cisco Software Management and smart account?
  • Considering that Cisco SD-WAN appliances do not support Cisco smart licensing, what are the benefits of vManage and smart account integration?
  • How much throughput is permitted on the firewall and IPS enabled on the cEdge routers? (on the Templates "Default" and "High" resource options are available while there is no information available regarding the throughput)
  • As mentioned in the documents, for enabling more than 250Mbps crypto throughput activating Call Home is necessary! How is it supposed to work when SD-WAN devices in controller mode do not support smart licensing?
  • Regarding Cisco NFVIS deployment on any X86 platforms, what are the OS type, installation prerequisites, and minimum hardware requirements?
0 Replies 0
