Showing results forĀ
Search instead forĀ
Did you mean:Ā
SDWAN Cedge to vManage UDP Packet Length
zarni tun
As per above picture, telco gateway router replies ICMP type 3 Code 4 message to the cEdge router patternly, when cEdge trying to send UDP packet of >1500 length to vSmart. My question is
1. Do I have to remove DF bit with "clear-dont-fragment" command?
2. Why that UDP packet size is so big?
What MTU value do you use for transport interface/ subinterface?
Clear DF is possible for tunnel interface and for traffic between cedge-cedge.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/ios-xe-17/systems-interfaces-book-xe-sdwan/configure-interfaces.html
HTH,
HTH,
