SDWAN CLI to GUI
AbuRafay63
Dears,
I need guidance that how i can change configuration mode from CLi to GUI mode in sdwan. Want to manage devies through vManage. Any guide available please share. Also share what points i need to have in mind while doing this change. Thanks
vManage: 20.3.3.1
contollers: 20.3.3
cEdge: ISR4k
BR:
Octavian Szolga
Level 4
Level 4
All you need to do is just carefully prepare the template per device type so that it corresponds with the existing CLI configuration.
If the template is correct, you won't have any issues with applying the template and moving the device from CLI to vManage mode.
BR,
Octavian
You can use CLI templates or Feature templates both with variables, with CLI template all you need to do is to copy the exact same configuration you have now in router and paste it in a new CLI template appropriate to the device model.
For feature templates is a bit more involved, as it has to be build, you can go to the following or find many how to videos in YouTube.
https://sdwan-docs.cisco.com/Product_Documentation/vManage_Help/Release_18.3/Configuration/Templates
