SDWAN MPLS - MPLS Tunnel is Down
Hi All,
I'm having some issues with my SD-WAN Lab and I hope you can help me :-).
Right now I have two vEdges routers vEdgeBR1(RID 4.4.4.4) and vEdgeDC1(RID 5.5.5.5) with two connections each (internet and MPLS). The internet connection works fine, I received the network prefix of both routers through OMP. But the tunnel between the two vEdge through the MPLS connection is down.
This is the topology:
When I run the command show bfd sessions the MPLS-MPLS session is down in both vEdges routers and they are not receiving packets:
I've been checking the logs and only can see this:
local7.info: May 28 13:57:16 vEdgeDC1 VDAEMON[1264]: %Viptela-vEdgeDC1-vdaemon-6-INFO-1400002: Notification: 5/28/2020 13:57:16 control-connection-state-change severity-level:major host-name:"vEdgeDC1" system-ip:5.5.5.5 personality:vedge peer-type:vbond peer-system-ip::: peer-vmanage-system-ip:0.0.0.0 public-ip:192.168.110.31 public-port:12346 src-color:mpls remote-color:mpls uptime:"0:00:06:39" new-state:down
local7.info: May 28 13:57:35 vEdgeDC1 FTMD[1254]: %Viptela-vEdgeDC1-ftmd-6-INFO-1400002: Notification: 5/28/2020 13:57:35 bfd-state-change severity-level:major host-name:"vEdgeDC1" system-ip:5.5.5.5 src-ip:172.16.1.2 dst-ip:172.16.0.2 proto:ipsec src-port:12366 dst-port:12366 local-system-ip:5.5.5.5 local-color:"mpls" remote-system-ip:4.4.4.4 remote-color:"mpls" new-state:down deleted:true flap-reason:bfd-deleted
local7.info: May 28 13:57:35 vEdgeDC1 FTMD[1254]: %Viptela-vEdgeDC1-ftmd-6-INFO-1400002: Notification: 5/28/2020 13:57:35 bfd-state-change severity-level:major host-name:"vEdgeDC1" system-ip:5.5.5.5 src-ip:172.16.1.2 dst-ip:172.16.0.2 proto:ipsec src-port:12366 dst-port:12366 local-system-ip:5.5.5.5 local-color:"mpls" remote-system-ip:4.4.4.4 remote-color:"mpls" new-state:down deleted:false flap-reason:na
Does anyone have the same problem?
Dan Frey
Could be a NAT issue.    Color MPLS uses "private peer address" and I see your NATing at the MPLS router.   Is there IP reachability between the two sites using  172.16.1.2 <---> 172.16.0.2 addresses without NAT?   Can the MPLS addresses reach the controllers without NAT?   If there is NAT involved on the MPLS network change the color to a public one like "biz-internet"   If you want to keep the color MPLS then remove NAT from all the MPLS connections.
Hi @Dan Frey
Each vEdge router can reach the other without nat but reach the controllers through the NATing of the MPLSRouter.
I've changed the color from "mpls" to "biz-internet" but the tunnel is still down.
I've changed my topology to make the vEdge reach the controllers without NAT, and I've assigned the color "biz-internet" and now the tunnel is UP.
Is there configuration when each vEdge communicates without NAT between them but need NAT to reach the controllers?
The output of show bfd sessions looks like NAT is still taking place since the DST port (15832) is not one of the standard ports documented here:  https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/sdwan-xe-gs-book/cisco-sd-wan-overlay-network-bringup.html#c_Firewall_Ports_for_Viptela_Deployments_8690.xml
