SDWAN OMP Mutual Route Leaking Issue
spenc02
I am attempting to leak routes from my employee VPN to the IOT VPN and vice versa. It is working without issue on the first sequence; however, I cannot get the second sequence (IOT to EMP) to function. I've tried to simply leak routes from IOT to EMP using the same logic as EMP to IOT, but for some reason it fails. I have tried with and without a prefix-list to the same result.
control-policy leak-routes-v12
  sequence 1
   match route
    prefix-list DC-SERVICES
    vpn-list    EMP
   action accept
    export-to
     vpn-list IOT
  sequence 11
   match route
    prefix-list IOT-SEGMENTS
    vpn-list    IOT
   action accept
    export-to
     vpn-list EMP
  default-action accept
apply-policy
site-list DC
  control-policy leak-routes-v12 in
Are your IOT routes originated from DC or what?
Reversing match and export does not mean that it will work. Important point here to which updates you do export. Based on your policy, vsmart does export for routes coming from DC. From DC you have only DC prefixes, not IOT, havent you?
HTH,
11 Replies 11
Show omp route <- share this and point whcih subnet you leaking between two vpn
MHM
I couldn't paste the relevant output in the reply for some reason, but have attached it here.
share below outputs from vSmart:
show omp routes vpn 10
show omp routes vpn 20
HTH,
The routes to be leaked are present in their native VPN on the vSmart controller; however, they are not present in the destination VPN not present in the "show omp routes vpn 20 advertised" output.
You should have three control policy:
DC-IN , this should match VPN10/ DC services prefixes > export to VPN20
DC-OUT, this should match VPN20/ IOT prefixes > export to VPN10
HQ-OUT, this should match VPN20/ IOT prefixes > export to VPN10
The problem is even though you have route in VPN 20 on DC, vSmart does exporting only if they received from DC routers, however these IOT routes are coming from other sites. Your policy dictates to vSmart that if you receive routes matching IOT prefixes from DC, then export to VPN10 (however, there is no such route).
HTH,
The control policy always has to be inbound to the DC site (or more accurately where vSmart resides)  for route leaking unless I’m missing something?
It also doesn’t work when I setup a single leak policy to leak from IOT to EMP but the other direction works without issue. In the topology policy I’m just reversing the “match” and “export to” VPNs yet it doesn’t work when I try IOT to EMP but works fine from EMP to IOT.
Inter-Service VPN leaking in same Site
Try
Vpn 10
Route-import-service  from vpn20
If not work open TAC
MHM
HTH,
The IOT VPN does not exist on the DC cEdges so there are no routes from that site. Only branches and HQ site have IOT routes.
policy
lists
vpn-list vpn-list-emp
vpn 10
vpn-list vpn-list-iot
vpn 20
site-list DC
site-id 2
site-list NONDCSITES
site-id 1
site-id 4
site-id 5
prefix-list iot-prefixes
ip-prefix 10.1.101.0/24
ip-prefix 10.4.101.0/24
ip-prefix 10.5.101.0/24
control-policy iot-to-emp-leak-v1
sequence 1
match route
action accept
export-to
apply-policy
site-list DC
control-policy iot-to-emp-leak-v1 in
I now understand what you were saying and found some additional insights on a blog post. It's now working. Thanks for your assistance!
For anyone who stumbles upon this, this is the working policy:
policy
lists
vpn 10
vpn 20
site-id 1
site-id 4
site-id 5
prefix-list default-only
ip-prefix 0.0.0.0/0
sequence 1
match route
action accept
export-to
apply-policy
That why I mentioned in inter-service VPN in same site (DC)
Now ot clear and your solution is OK
You apply this policy to all site with direction IN
The prefix is export in vsmart from VPN-x to VPN-y.
Glad issue solved
Have a nice weekend
MHM
