Setting BANDWIDTH metric on dynamic tunnel interface with vmanage templates
aarato
By default the BW is set to 100K on the tunnel interface and the monitoring tools are complaining about this. is there any way to override this?
Tunnel2 is up, line protocol is up
Hardware is Tunnel
Interface is unnumbered. Using address of GigabitEthernet0/0/2 (x.x.x.x)
MTU 9980 bytes, BW 100 Kbit/sec, DLY 50000 usec,
inderdeeps
Level 4
Level 4
Yes you can do that with vManage Templates or with CLI. With CLI as below
VPN Interface Ethernet - Viptela Documentation (cisco.com)
Share your current template we can have a quick look.
Inderdeep Singh
www.thenetworkdna.com
****RATE MY REPLY IF YOU LIKE MY RESPONSE****
inderdeeps
Level 4
Level 4
@aarato Are you able to resolve your issue ?
Amplify6326
I'm not the original poster and maybe it's better to start a new topic as this one is already a couple of years old. But how would someone go about doing this?
My tunnel interface numbers are mostly the same as evidently they based on the physical interface numbers that are used and most of the time we've used the same ones. However, some of my WAN interfaces use sub-interfaces due to Dot1Q encapsulation from the carrier. Will I need a separate CLI template for these to set the bandwidth on these interfaces?
Is there truly no way to set the tunnel bandwidth dynamically other than to have enabled "auto-bandwidth-detect" during PnP onboarding?
