show mpls ldp neighbor with no results
daliclb
I'm working on this architecture . So I wanted to configure mpls in it . I typed these commands :
PE11 : int loopback 0
ip address 1.1.1.1 255.255.255.255
no sh
exit
ip cef
mpls ip
mpls label protocol ldp
mpls ldp router-id loopback 0 force
int g1/0
ip address 192.168.1.17 255.255.255.252
no sh
exit
int g2/0
ip address 10.1.1.1 255.255.255.252
mpls ip
no sh
P11: int loopback 0
ip address 5.5.5.5 255.255.255.255
no sh
exit
ip cef
mpls ip
int g1/0
ip address 10.1.1.9 255.255.255.252
mpls ip
no sh
exit
int g2/0
ip address 10.1.1.50 255.255.255.252
mpls ip
no sh
exit
int g3/0
ip address 10.1.1.13 255.255.255.252
mpls ip
no sh
exit
P12: int loopback 0
ip address 6.6.6.6 255.255.255.255
no sh
exit
ip cef
mpls ip
int g1/0
ip address 10.1.1.14 255.255.255.252
mpls ip
no sh
exit
int g2/0
ip address 10.1.1.17 255.255.255.252
mpls ip
no sh
exit
P13: int loopback 0
ip address 7.7.7.7 255.255.255.255
no sh
exit
ip cef
mpls ip
int g1/0
ip address 10.1.1.18 255.255.255.252
mpls ip
no sh
exit
int g2/0
ip address 10.1.1.21 255.255.255.252
mpls ip
no sh
exit
P14: int loopback 0
ip address 8.8.8.8 255.255.255.255
no sh
exit
ip cef
mpls ip
int g1/0
ip address 10.1.1.22 255.255.255.252
mpls ip
no sh
exit
int g2/0
ip address 10.1.1.25 255.255.255.252
mpls ip
no sh
exit
int g3/0
ip address 10.1.1.54 255.255.255.252
mpls ip
no sh
exit
PE12: int loopback 0
ip address 2.2.2.2 255.255.255.255
no sh
exit
ip cef
mpls ip
int g1/0
ip address 192.168.1.18 255.255.255.252
no sh
exit
int g2/0
ip address 10.1.1.2 255.255.255.252
mpls ip
no sh
exit
so whenever I try to run show mpls ldp neighbor theres no result
so what is wrong with the commands what should I do ?
First
int g1/0 in PE 11 have no mpls ip command
Second
You need to run ospf (global) in all routers' ldp need reachability to work
MHM
